Topic: Minor cosmetic issue
Strange one this. I have a Bootcamped Mac with both versions of VDJ8.
In the Mac version if I enter the sample editor for instance, the buttons are either grey or light up blue when activated as it shows in the manual.
On my PC version I don't get the blue colour, just 2 slightly different shades of grey. This makes it very difficult to see what is selected and what is not. Same in the Audio Settings, etc.
Anybody know how to fix this?
geposted Sat 31 May 14 @ 2:49 pm
It's related to the Windows colour scheme.
If you choose a basic scheme, you don't get the colours.
I did report this ages ago, but I guess it's not a priority.
geposted Sat 31 May 14 @ 2:58 pm
Just checked, the colours work with Aero Theme.
I normally use the Basic Classic Theme as this was meant to be better in previous versions with less stress on the processor.
geposted Sat 31 May 14 @ 4:13 pm
