Forum: VirtualDJ Plugins
Topic: My Library - The essential database tool - Page: 8
You sir, need a Nobel prize.
geposted Wed 28 Jan 15 @ 9:37 pm
There is an error in the genre filter "Trance".
Don't know the exact script at the moment, but the action contains something like "... or genre contains pop".
geposted Wed 18 Feb 15 @ 3:30 am
exists =1 and trance contains trance or filepath contains rock or title contains trance
Should be this I guess -> exists =1 and genre contains trance or filepath contains trance or title contains trance
BTW I would always expect trance to contain trance :-)
geposted Wed 18 Feb 15 @ 9:56 am
Yes that's what i meant, thank you :)
geposted Wed 18 Feb 15 @ 10:01 am
I just got it... Works great.
Question... why VDJ Tag Editor doesn't modify ID3TAG in Windows Explorer???
Thx
geposted Sun 15 Mar 15 @ 9:52 am
V8 works with (I believe) the 2.3 format
geposted Mon 16 Mar 15 @ 3:13 pm
Perhaps this may help everyone out there a little bit more. The location where these files need to go is in the (%USERPROFILE%) location on Windows machines (Documents and Settings, My Documents, or Documents depending on what version of Windows you are running), and the User Documents folder (Of the user that installed Virtual DJ, not its install location) on OS X machines. So generally speaking, that will translate to:
Windows:
C:\Documents\
OS X /Users/username/Documents/VirtualDJ/Folders/
I took a screenshot on my OS X machine, hopefully that lessens some of the confusion people have. Also it would be nice to update the install instructions so that it reflects the correct technical documentation and nomenclature of the different operating systems being used by Virtual DJ users. :)
geposted Fri 27 Mar 15 @ 3:00 am
carneriHome userMember since 2014
Great job, it's nice. Just a question? Can I make changes in GENRE?, I'm in Puerto Rico & we use latin music like salsa, bachata, merengue, etc
geposted Fri 27 Mar 15 @ 12:48 pm
Of course. You can fully customize the filter folders to your needs.
geposted Fri 27 Mar 15 @ 2:50 pm
Great Job ~~!!!
geposted Thu 23 Apr 15 @ 8:25 am
RUNE N°1 :-)
geposted Fri 24 Apr 15 @ 7:49 pm
SoundsDJPRO SubscriberMember since 2015
Thanks Man! That's amazing. Appreciate the Share.
geposted Mon 04 May 15 @ 8:40 am
Great work ..thanks alot
geposted Thu 28 May 15 @ 5:35 pm
Absolutely killer work.. mad props!
geposted Sat 30 May 15 @ 6:23 am
Thank you :)
geposted Sat 30 May 15 @ 3:12 pm
I will definitely give it a try, I just got the Numark NV and it will help I think tremendously with sorting out music.
geposted Wed 17 Jun 15 @ 9:35 pm
thank you so much they need to add this to the next update
geposted Wed 01 Jul 15 @ 1:29 am
hi, this looks great, iv downloaded & dropped into my VDJ file but it does not show up in my VDJ8, I looked in the VDJ file and I can see it there, what am I doing wrong
geposted Tue 28 Jul 15 @ 3:50 am
You have to extract the zip file and place the content of the zip file into the "folders" folder of your VDJ folder.
geposted Tue 28 Jul 15 @ 9:40 am
Something appears to be wrong with the live lists, I have a 92 bpm track on deck and the bpm compatibility live list is giving me my entire db
similar with compatible,
Is it just me?
geposted Fri 14 Aug 15 @ 6:20 am
77%
