May most of my problems are allready resolved, reported or changeable in the configuration interface.
It would be very helpfull to recieve a feedback.
- the configuration interface sometimes does not respond on the modificated option changings.
the missing save button makes me as user also insicure, when i change something
- auto play prewview stops when you choose files from other folder.
play prewview on the right side of the interface is not userfriendly, as it was on the bottom, like on the vers.7
Who needs the Taginformations during a stressfull Gig ?
- the assignment of the audio configuration needs often many calls to recieve the option, what i selected.
especially the assigment of the prewview works not properly
- the fine adjust of the waveforms by using the cursor is very hard to handle now. it shoud be made softer, to move the lines on the same beat.
- the left sync button of the Mixtrack Quad did not respond on my orders.
- Pitchfader Option must be assigned ( if 6,10,12,16 ect. ) by each track
- it would be nice, if we could recieve a confirmation window/popup when a new upgrade is downloaded and installed
- the sound limiter allway struggle down the maximum loudness. plays the tracks not the highest possible level.
- i miss a keychanger/fader on the standard skin
geposted Sun 01 Jun 14 @ 10:12 am
i agree on some of those ..... the tag info would be better to invoke with a click , and would be better to have the sidelist instead
on screen you could have the automix box plus the sidelist
the missing save button ? i don't get that at all
geposted Sun 01 Jun 14 @ 1:22 pm
