Hi,
I don't know if this is a bug. When the getRemixWhileParsingFilenames is set to "no" it still shows up in the options window when trying to get the filename from the tags:
![](/image/93644/137916/filename issue.jpg)
Is this because the Remix info is also in the Title field?
geposted Sun 01 Jun 14 @ 10:23 am
Yes its because it is in the title field also. Here you can see I have the choice of with or without remix.
I don't think there are any options to change in settings at the moment to change the format.
![](/image/58811/137918/2014-06-01_1636.png)
geposted Sun 01 Jun 14 @ 10:37 am
OK. It's something that should be addressed because filenames usually use this format: artist - title (remix)
geposted Sun 01 Jun 14 @ 11:13 am
So how do you get the tags from the filename?
geposted Sun 01 Jun 14 @ 11:42 am
Thats exactly what it does do - but because you have the remix in the title also it is showing it twice - look at my example.
Click the small button in the top section next to Artist and Title.
geposted Sun 01 Jun 14 @ 11:45 am
Got it. Thanks.
geposted Mon 02 Jun 14 @ 10:25 pm
