Topic: not a huge issue but.... [Solved]
i used to use the brake funcion alot but since v8 its gone, there is a brake start but no brake to stop, will it be re added or am i missing something, otherwise its a pretty good update
geposted Sun 01 Jun 14 @ 1:03 pm
DJ KozPRO InfinityMember since 2007
I believe its rampStopTime in settings.
geposted Sun 01 Jun 14 @ 1:34 pm
cheers buddy ill have a play around and see if i can get something to play with
geposted Tue 03 Jun 14 @ 1:19 pm
thats sorted it thanks for pointing me in right direction
geposted Tue 03 Jun 14 @ 1:25 pm
Nevermind, I'm too late. Glad you found your answer.
geposted Tue 03 Jun 14 @ 1:27 pm
the rampstoptime thing works great for me too :) thanks alot for the tip
geposted Tue 09 Dec 14 @ 8:52 am
