Hello,
I can't seem to find the proper coding. Is there a way to map the DDJsx encoder to change the view from mixer, to video, scratch, and master.
I would like to use 'shift _enc browser' to change to the different views. Thanks in advance. FLeX
geposted Mon 02 Jun 14 @ 3:27 am
For a button, use ..
skin_panelgroup 'mixer' +1 for forward change or skin_panelgroup 'mixer' -1 for backwards change.
For an endless encoder, try..
param_greater 0 ? skin_panelgroup 'mixer' +1 : skin_panelgroup 'mixer' -1
geposted Mon 02 Jun 14 @ 9:00 am
didad, thanks ... I will get back to you soon. thanks again.
geposted Mon 02 Jun 14 @ 9:04 am
Hello DJDad,
It works and what it does is go from mixer to master to video to scratch.
I reversed the numbers but it doesn't switch in the same order as laid out on the screen.
The parameter greater didn't pop up as I typed, but bigger did. No change when I used either script.
I'm I missing something in the mapped? BTW, I'm using the encoder. Thanks in advance. FLeX
geposted Wed 04 Jun 14 @ 8:19 am
This worked for me, scrolling in the correct order, so not sure why it doesn't for you.
You can try this code, which specifically uses the panel names to ensure they move in order.
skin_panel 'audiomixer' ? skin_panel 'videomixer' : skin_panel 'videomixer' ? skin_panel 'scratchmixer' : skin_panel 'scratchmixer' ? skin_panel 'mastermixer' : skin_panel audiomixer
geposted Wed 04 Jun 14 @ 9:45 am
OK I will make sure there is no typo in the original script.
If it works for u, there must be something on my side I missed. Thank you. I will try again.
geposted Wed 04 Jun 14 @ 9:50 am
djdad and djtouchdan, thank you. I don't know why the first code didn't work. I end up using the second code. Its GTG. Thank you. FLeX
geposted Tue 10 Jun 14 @ 7:49 am
