Topic: VirtualDJ8 and DenonMc6000 with mic
olufemiPRO InfinityMember since 2010
Can anyone provide a fool proof setup for VDJ8 and DenonMC6000 using Windows8 and microphone? Setup needs to take into consideration broadcasting. I have issues also with prelistening the cued up track using the split cue button on the DenonMC6000. Headset mic combination is attached to the Denon. So far on my attempts to broadcast, there is no voice transmission. Thanks
geposted Mon 02 Jun 14 @ 3:32 pm
Try hitting the POST button on the mic channel. It was the only way I could get the mic to pass through to the computer.
geposted Mon 02 Jun 14 @ 7:13 pm
Thanks ! Ill try that on my next opportunity
geposted Tue 03 Jun 14 @ 6:18 pm
The post trick worked in that I was able to hear voice transmission during broadcast. However the voice was extremely faint even with microphone level on the denon set at max. In the computer the DNMC6000 is set as the default for the mic and it is set @ 100 under microphone properties/Levels
geposted Tue 03 Jun 14 @ 9:15 pm
