Hi,
I finally got round to downloading VirtualDJ 8 for my MacBook today (Mac OSX v10.9.2).
It looks really smart, and I'm looking forward to trying it out properly. Unfortunately, I can't seem to get one of the more basic functions working - M3U playlists.
The user manual says M3U playlists are readable from anywhere now. So I navigate to my 'Music' folder from the VirtualDJ 8 browser window where there are a number of M3U playlists which I have previously successfully imported into VirtualDJ 7. None of them play. When I drag them into the playlist window, the icons all have a red cross over them. If I right-click the file and select 'Tag Editor' it says 'Error opening file' at the bottom of the tag editor window.
After a bit of experimentation, it appears that VirtualDJ 8 doesn't support relative path names in M3U playlists.
Is this correct?
As it stands, I can open my M3U playlists in any media player application on my MacBook, except VirtualDJ 8.
Is this a bug?
Thanks.
Is this correct?
Is this a bug?
Thanks.
geposted Tue 03 Jun 14 @ 4:12 am
I upgraded to "version 8.0.0 mac build 1828.686" today, and this is still an issue.
Will this problem be addressed in a future build?
geposted Tue 17 Jun 14 @ 1:19 am
So you mean that an entry like this in a m3u file doesn't work:
#EXTINF:181,Loreen - Euphoria - Single Version
New\Loreen - Euphoria - Single Version.mp3
It works fine on my PC version, so if it doesn't work on mac, I guess it must be a bug
geposted Tue 17 Jun 14 @ 2:26 am
Yes, that's correct.
Relative pathnames (both windows '\' and Mac '/') work on the Windows version, but they do not work on a Mac (neither windows '\' or Mac '/').
How do I log this as a bug?
geposted Tue 17 Jun 14 @ 4:11 am
Should be fixed in the next build
geposted Tue 17 Jun 14 @ 4:55 am
Great! Thanks!
geposted Tue 17 Jun 14 @ 5:20 am
