Yeah just got home and had another go and this is not good, we should be given the choice. This isn't good at all..............
geposted Wed 04 Jun 14 @ 5:25 pm
Ok well I guess I can't change the quantized timing, that's just weak sauce all day long!!
Now are the names supposed to show in a sample slot on the skin?? If so there not working for me and my sample buttons lite up as if that sample is on. Is this suppose to happen??
geposted Fri 06 Jun 14 @ 8:24 am
At the moment Huey - i think the remix_mode uses different code to populate the button text. Taking something from the POI editor.
I'll see if i can figure the code out.
geposted Fri 06 Jun 14 @ 8:29 am
Thanks bro!! Most appreciated!!
geposted Fri 06 Jun 14 @ 8:31 am
Dodge57 wrote :
a question : what is "has_sample" ???
geposted Fri 06 Jun 14 @ 11:06 am
haven't seen has_sample but i would guess the same has_cue
You can use it like this:
<button action="sampler_pad 1" visible="has_sample 1">
So the button will not be visible unless there is something in sample pad 1.
geposted Fri 06 Jun 14 @ 11:09 am
The correct action is sampler_loaded, e.g: sampler_loaded 1 will return true if a sample is loaded on pad 1.
geposted Fri 06 Jun 14 @ 11:15 am
Do you have a video explaining the Remix Mode, as I only see this empty.
![](/image/2664/138458/empty.JPG)
The user manual is of no help regarding this!
geposted Fri 06 Jun 14 @ 5:21 pm
It'll be empty unless you either add remix points to a track using the POI editor, or load a track that VDJ has automatically assigned some remix points to.
When looking for the latter, VDJ seems to prefer tracks that have really obvious changes in them.
geposted Fri 06 Jun 14 @ 5:53 pm
Groovindj, thanx, it worked after I created remix points.
I just noticed that for one of the tracks out of 100, these were created automatically, so the best option will be to go for the manual method.
geposted Sat 07 Jun 14 @ 6:07 am
