I'm going to slowly work through all the bits that aren't perfect,
#1 The bpm editor
http://tinypic.com/r/2s6nd6g/8
Add a button to set the down beat/beat 1, yes it can be dragged but that's a farce with long intro's
Zoom buttons, not everyone has a scroll wheel.
#1 The bpm editor
geposted Tue 03 Jun 14 @ 8:44 am
#2 The POI editor
http://tinypic.com/r/20sstw3/8
Show all gets messy, a drop down menu with options
All
Hotcues
Action Cues
Remix points
Automix
Saved loop
Load point
Custom (with a text box to set custom All, !Automix, !load point)
Also add zoom *2, /2 buttons,
All
Hotcues
Action Cues
Remix points
Automix
Saved loop
Load point
geposted Tue 03 Jun 14 @ 8:51 am
In case you didn't realise you can zoom using the blue position bar too, not just with a scrollwheel.
geposted Tue 03 Jun 14 @ 9:24 am
I do know that, but just feels 'rough', having to use it once isn't so bad but several times, for several tracks and it feels like a chore.
geposted Tue 03 Jun 14 @ 1:09 pm
POI editor should have 'snap to' 1/64th 1/32th etc
geposted Mon 16 Jun 14 @ 9:42 am
