Topic: Denon mc6000 shift+vinyl key stops music
Have noticed this a few times. When I have a song playing and I hold down the shift button and press the vinyl button on the Denon mc6000 the song stops playing. Then if I press the shift button again and hold it down the song carries on, but stops when I release the shift button.
Pressing the shift+vinyl puts you in vinyl mode for scratching etc. It I press shift+bend to put me back into cd mode everything woks ok, and when I go back to vinyl mode that works ok.
It only stops the music the first time you change to vinyl mode on each deck, then if you go back to cd mode and back to vinyl again, its all ok.
Not sure if this is something I am doing wrong, or maybe its a bug. Just thought I would share. Thanks.
geposted Tue 03 Jun 14 @ 2:32 pm
