There is an issue with the mapper - loops on NS 7 II. If you press the loop button, 3 random buttons light up in green and the last button lights up in pink. I cant engage a 16 beat loop with the button that lights up in pink which was previously(v7) the button that used to engage the loop. When is that going to be corrected? Thanks
geposted Wed 04 Jun 14 @ 6:44 am
Pressing the loop button once will activate the 1st phase of looping (Manual). The green buttons are (In) set point and (Out) set point I can't remember what the other green button does and I believe the red/pink button is to exit loop.
Pressing the loop button again will activate the 2nd phase of looping (Automatic). The eight pads will light up in pink with the first being I believe (1/8) going all the way up to (8)
Using the parameters button on the side will change the looping length.
Hope this helps
Cheers,
- dee_jay_boy
geposted Wed 04 Jun 14 @ 7:22 am
Hi dee_jay_boy
Thanks for your response. Do you know how i can change the 1st phase to be automatic and the 2nd phase to be Manual
I also want the loops to start from 1/4 and end with 16.
Thanks
Thanks
geposted Wed 04 Jun 14 @ 11:59 am
murayadavid wrote :
Hi dee_jay_boy
Thanks
Thanks
You are going to go into your controller mapper and just change the parameters under LOOP MODE
From : var 'padmode' 5 ? set 'padmode' 4 : set 'padmode' 5
To: var 'padmode' 4 ? set 'padmode' 5 : set 'padmode' 4
![](/image/86357/138285/Virtual.jpg)
I will look into the starting from 1/4 and ending to 16, I believe it will probably start from 1/8 and up to 16 (1/8, 1/4, 1/2, 1, 2, 4, 8, 16)
Cheers
- dee_jay_boy
geposted Wed 04 Jun 14 @ 10:25 pm
murayadavid wrote :
Hi dee_jay_boy
Thanks
Thanks
Okay figured out how to change the starting position for each pad. Look at the picture below and for each PAD# you will be changing the "var 'padmode' 4 ? loop 0.125"
PAD1 - From: var 'padmode' 4 ? loop 0.0625 To: var 'padmode' 4 ? loop 0.125
PAD2 - From: var 'padmode' 4 ? loop 0.125 To: var 'padmode' 4 ? loop 0.25
PAD3 - From: var 'padmode' 4 ? loop 0.25 To: var 'padmode' 4 ? loop 0.50
PAD4 - From: var 'padmode' 4 ? loop 0.5 To: var 'padmode' 4 ? loop 1
PAD5 - From: var 'padmode' 4 ? loop 1 To: var 'padmode' 4 ? loop 2
PAD6 - From: var 'padmode' 4 ? loop 2 To: var 'padmode' 4 ? loop 4
PAD7 - From: var 'padmode' 4 ? loop 4 To: var 'padmode' 4 ? loop 8
PAD8 - From: var 'padmode' 4 ? loop 8 To: var 'padmode' 4 ? loop 16
You will also have to do the same under each LED_PAD# if not you will notice that the wrong pad will light up but the right loop will be triggered.
![](/image/43068/138286/Virtual2.jpg)
Cheers,
- dee_jay_boy
geposted Wed 04 Jun 14 @ 10:46 pm
Thanks this is very helpful. I will try this when I get home.
Thanks a lot!
Thanks a lot!
geposted Thu 05 Jun 14 @ 11:14 am
Thanks a lot!
Thanks a lot!
Yeah no problem let me know if it worked :-)
geposted Fri 06 Jun 14 @ 6:35 am
Yes!!!!!!!!!! It worked!!!
Thank you very much!!!
Thanks again...
Thanks again...
geposted Fri 06 Jun 14 @ 12:10 pm
I'm unclear on how to do this in virtual 8? These are the settings I have
![](/image/62405/209256/image.jpg)
geposted Mon 17 Oct 16 @ 3:11 pm
