Topic: parameter adjustment knobs
mojo193PRO InfinityMember since 2006
the parameter knobs number 2 don't work . I can't adjust the speed of my backspins or loopouts or flippindouble
geposted Wed 04 Jun 14 @ 7:28 am
RobRoyPRO InfinitySenior staffMember since 2012
Onyl in the Software or also when a controller is connectet ? Default Skin ?
Which build an OS do you use ?
geposted Wed 04 Jun 14 @ 7:39 am
with both the controller and the software
I'm using Vista
LoopOut v2.01 and Backspin are the two effects that don't allow me to activate knob 2 parameter
geposted Thu 05 Jun 14 @ 8:05 am
Not shure if these effect are already ported to version 8.
You need to use version 8 effects as the interface between effects and Software has changed. Some older effects are still running but not all.
Greets, Heiko
geposted Thu 05 Jun 14 @ 8:21 am
