Forum: Old versions
Topic: ftd2xx.dll Driver
I'm still using VDJ 7.4, and was running into a few small errors, when a friend advised that the issue was probably that i hadn't updated windows for 6 months (I'm running windows 8). I then downloaded 8.1 and since then when I try to run VDJ as it opens it gives me an error message stating:
"The program can't start because FTD2XX.dll is missing from your computer. Try reinstalling the programme to fix this problem."
Has anyone run into this issue before?
Should I just reinstall VDJ 7.4 (I don't want to install VDJ8 yet, when I have some learning time available i'll install that!) or should I search online for that driver, and if so where would I paste that driver to?
geposted Thu 05 Jun 14 @ 10:31 am
Thanks Groovin
