Using VDJ8 with Numark Mixtrack Quad controller when finishing a set and require to shut down the laptop it freezes and the only way to close the program is by going into task manager. Is anyone else having a similar issue?
I'm using a Novatech A15HC with an I5 processor with 8gb of ram with dedicated nvidia graphics card.
geposted Fri 06 Jun 14 @ 4:09 am
You using the Virtual DJ 8 Skin ? Also make sure you update your Video card for the latest drivers
geposted Fri 06 Jun 14 @ 6:57 am
Yes i am using the default 4 deck skin for VDJ8 and updated the driver for the nvidea yesterday and its still happening
geposted Fri 06 Jun 14 @ 8:09 am
Does it freeze when the Controller is not plugged in .
geposted Fri 06 Jun 14 @ 2:18 pm
just for curiousity try this ...after you click the upper right "X" to close vdj ...push any button on your controller.this works on my Xponent,which then close Vdj.might be a driver issue..
geposted Fri 06 Jun 14 @ 4:48 pm
Just updated graphics driver again and reset VDJ8 to all standard settings and it seems to be ok now. Now going to run test overnight. Cheers
geposted Sat 07 Jun 14 @ 12:55 pm
