Is there a way to change the bitrate to record on 320 kbps .mp3? The standard in recording in mp3 format is 192 kbps on virtual dj. I would rather record on 320 kbps and convert down than not have it at all.
geposted Fri 06 Jun 14 @ 1:28 pm
settings/ set recordQuality to "high" and you will record in 320 kbps
geposted Fri 06 Jun 14 @ 1:52 pm
There is a problem
how i change the recording setting to 320kbps.
i checket setting but there is not given.
geposted Fri 05 Sep 14 @ 5:54 am
did you check the checkbox for "advanced settings" on the settings page?
geposted Fri 05 Sep 14 @ 5:58 am
djshivam4v wrote :
There is a problem
set recordQuality in settings/ adanced options to "high"
geposted Fri 31 Oct 14 @ 4:26 am
A easy fix for a user to do but.... shouldn't 320Kb/s be the default setting? I think it should.
geposted Fri 31 Oct 14 @ 9:40 am
I concur. 320Kb/s for the default.
geposted Fri 31 Oct 14 @ 9:43 pm
it is not possible
not bit-rate option on vdj8. only 192kbps
geposted Sat 29 Nov 14 @ 4:25 am
yes it is
http://pbrd.co/1FFKX2p
geposted Sat 29 Nov 14 @ 5:01 am
how do i record on virtual dj 8
geposted Tue 27 Jan 15 @ 3:13 pm
Please see here on the Master Tab on default Skin:
geposted Wed 28 Jan 15 @ 12:44 am
I would like to know if there is a way to record a live band taking signal from their mixer and using one of the RCA Inputs ? I have a DDJ-SZ I took the output from a bands mixer and put it in Input 4 I had signal but could not figure out how to get Virtual DJ to record the live set
geposted Sun 08 Feb 15 @ 8:33 pm
There is no section of record in settings. Help
geposted Wed 20 May 15 @ 1:18 am
geposted Wed 20 May 15 @ 1:32 am
Thanks a lot!!
geposted Wed 20 May 15 @ 1:41 am
hi i have a big problem when i record my mixers i can't listening after i save it in my desktop but no sound i think that is a set up problem please help me i have vdj8 ,a pioneer ddj. ergo and a macbook pro computer .Thank
geposted Fri 12 Jun 15 @ 9:35 pm
First, are you recording from tracks you own or content unlimited? I ask because CU tracks will not record.
Second, can you post a screenshot of your recording settings?
geposted Fri 12 Jun 15 @ 9:39 pm
hey ihave aproblem,icant find the files that i record in vatual dj
geposted Fri 28 Aug 15 @ 8:21 pm
You specify where the file is recorded to in the record settings. Check out page 87 of the users manual for more information. It can be found in the virtual DJ home folder or here:
http://www.virtualdj.com/documents/Manuals/VirtualDJ8_User_Guide.pdf
geposted Sat 29 Aug 15 @ 1:25 pm
I record my mixes and save them in my desktop.
The problem is that I cannot play them.
Please, I need help here because I am organizing a party next week.
geposted Sun 10 Jan 16 @ 3:01 pm
