Hey, is there anyway to convert this 'Recorded may31.vdjsample' that i recorded by mistake to the sample, instead of recording to file?
geposted Fri 06 Jun 14 @ 2:37 pm
just play the (mistake) sampler and record it to a file...should work fine...;-)
geposted Fri 06 Jun 14 @ 3:15 pm
yea it should, but it was a 6hr gig. smh
geposted Fri 06 Jun 14 @ 7:11 pm
just rename it to ogg
thats the format when you load it to the deck
geposted Sat 07 Jun 14 @ 1:42 am
renaming to .ogg doesnt work
geposted Sat 07 Jun 14 @ 6:55 am
I don't think there is an easy way to do this i'm afraid. Only Roys suggestion.
The samples are encoded in a way that they can only be used with Virtual DJ. So you can't just change the extension and hope it will work.
geposted Sat 07 Jun 14 @ 9:14 am
djtaliban I have sent you a PM about this.
geposted Sat 07 Jun 14 @ 10:51 am
Like I said, you can't just rename it because VDJ adds a bit of data to the start of the file.
If you remove that header data, so the file starts where the word Ogg is, then it will play.
You need to edit the file (use Notepad ++ for example). Look for the first use of the word Ogg, and remove everything before that.
thanks groovindj it worked
geposted Sat 07 Jun 14 @ 11:01 pm
