Topic: Naming Sampler Banks
DjBoy01PRO InfinityMember since 2009
Hello,
Might not be a bug but most likely is unless I'm doing it wrong. When creating a new bank and then go to configurations to rename it the name will disappear once you change bank. If I'm doing something wrong let me know but if is indeed a bank I'm pretty sure you guys probably know I just haven't seen it in any threads yet.
Thank You,
dee_jay_boy
geposted Sat 07 Jun 14 @ 6:43 am
apopsisdjPRO InfinitySenior staffMember since 2003
You can't rename a bank from the settings - Options.
There you can only see the last bank used (the active bank)
To rename a bank just select it from the left side of the browser - > Sampler
Right click menu.
geposted Sat 07 Jun 14 @ 6:52 am
Right click menu.
Awesome, thanks
geposted Mon 09 Jun 14 @ 5:21 am
