Hello when i set my mixtrack pro as my sound card in vdj8 it sounds bad if i change to internal everything is good or if i got to vdj7 sound is good with mixtrack pro as sound card. Thanks.
geposted Mon 09 Jun 14 @ 4:50 pm
Can you define "bad" ?
Have you optimized your computer for best performance ? http://www.virtualdj.com/wiki/Common%20PC%20Performance%20Issues.html
geposted Tue 10 Jun 14 @ 12:42 am
The usual three possible causes in VDJ 8 are:
wasapisharedmode
overclock
ultralatency
Try changing those settings (it may be just one of them).
wasapisharedmode
overclock
ultralatency
geposted Tue 10 Jun 14 @ 9:20 am
Like distortted or washy when i set the sound card as my internal and run the line out of the backnof my comp sounds fine if i switch the soundcard to the mixtrack pro and run out of the back of the mixtrack sounds almost under whater soundig
geposted Tue 10 Jun 14 @ 10:31 am
groovindj wrote :
wasapisharedmode
This was changed a few builds ago. Search Config->Options (tick advanced) for exclusiveAudioAccess
Change this to no.
geposted Tue 10 Jun 14 @ 6:04 pm
it was bad
geposted Sat 14 Feb 15 @ 9:40 am
how can i get a sound card on my VD8 system
geposted Sat 23 Dec 17 @ 9:37 pm
