Topic: Another Virtual Folder issue
I use my main PC to prep for a gig with Virtual Folders.
When ready, I copy my database file to the gig laptop as well as the Folders folder under My Documents\Virtual DJ for my Virtual Folders I created.
Apparently some of the Virtual Folders information appears to be included in the database as well but not all.
Then when I copy the Folders folder over they all appear in the gig laptop but then all songs in the Virtual Folders are doubled.
geposted Mon 09 Jun 14 @ 7:48 pm
Are you sure you copied the correct database.xml file ?
If both computers have identical database.xml and VirtualDJ Folder folders, then really there is no chance to see double files there.
geposted Tue 10 Jun 14 @ 12:24 am
Yes, I copied the database.xml file and the Folders folder. Once copied onto the laptop I always have to go in the virtual folders and remove the double songs. Very time consuming trying to prepare for a gig, or a couple of gigs.
geposted Mon 23 Jun 14 @ 5:53 am
Are there external hard drives involved in your scenario anywhere?
geposted Mon 23 Jun 14 @ 5:56 am
And if so, make sure both machines use the same drive letter for external drives.
geposted Mon 23 Jun 14 @ 6:37 am
