just one request about the transparency setting on the camera plugin can we have the back ground the videos or karaoke instead of blank ,so when we reduce the window size the video or karaoke song can be seen that would look really great ????
geposted Mon 09 Jun 14 @ 8:09 pm
How are you getting that? with the camara plugin on windows 7 I get the camara image maximized over the whole thing.no background colors....
geposted Mon 09 Jun 14 @ 8:30 pm
I'm using vdj8 and windows 8.1
geposted Tue 10 Jun 14 @ 2:35 am
I think it's transparent on vdj7 I never used it on vdj7
geposted Tue 10 Jun 14 @ 2:36 am
Check the new camera plugin you can resize and move the camera image it's great apart from the back ground is blank.
geposted Tue 10 Jun 14 @ 2:45 am
I'm sorry.I missed that.the one inside vdj's visualization? ..because as far as a downloadable plugin there's the camara8 and that is a mac plugin only..
Oh! ...got it..new update...
geposted Tue 10 Jun 14 @ 4:14 am
geposted Tue 10 Jun 14 @ 5:56 am
If you have something on the video output, and make the camera output transparent then what is on the output shows up behind the camera.
Are you after being able to make a colour transparent on the actual camera output?
geposted Tue 10 Jun 14 @ 9:32 am
For some reason the camera must override the video and keeps the whole screen blank even if I resize the camera screen
geposted Tue 10 Jun 14 @ 10:25 am
I had this issue the other day - but today it seems to be working.
Not sure what changed.
geposted Tue 10 Jun 14 @ 10:26 am
Ok thanks I will keep doing the updates and see how it goes thanks.
geposted Tue 10 Jun 14 @ 6:00 pm
Just keeping you informed that it's still the same the camera window still overrides all other windows even when your resize the window and make it transparent, I would be great if you could help with this.
geposted Thu 12 Jun 14 @ 5:43 pm
same here...vdj8 on windows 7 64bit...not checked vdj7,if this is a vdj8 plugin then I doubt you can open or even find it in 7..
geposted Thu 12 Jun 14 @ 6:20 pm
