Topic: Unknown / Unsure
Hey... not too sure if this is even a feature.. never mind a bug.. :-)
using the ramp adjust for start / stop.. so when using the Play / Pause, for playing deck, creates a braking effect.. but it doesn't work when running slip mode at same time.. if you know what i mean..
best way to describe it would be.. it works like that in another software (Daretomention) SDJ, is it a feature available in V8, or is it a possible bug that it doesn't "Roll" in slipmode.. am sure you guys now what i mean :-)
Cheers
Macky
geposted Tue 10 Jun 14 @ 11:18 am
