Hey Guys,
Was really puzzled when i came to check my karaoke for a gig, i got no lists showing in any of my karaoke directories.
![](/image/83794/139028/Karaoke_Niggle.png)
Quick check on the forum didn't turn up anything (only check a few posts related to a search for "Karaoke")
Anyway, turns out there's an option you have to select to show karaoke files that are zipped together.
![](/image/33926/139029/Karaoke_Fix.png)
Hope this helps some people.... seems to be there's an option/setting for everything!!!!
geposted Thu 12 Jun 14 @ 10:32 am
YOU ARE THE MAN!!!!! Thank you soooo much for posting this. I was pulling my hair out trying to figure out why my karaoke files would play in VDJ7 but not VDJ8....and thanks to you posting this...I can totally make the FULL switch to 8 now and not have to go back and forth anymore. Thanks again sir.
geposted Wed 23 Jul 14 @ 4:00 pm
Thank you
geposted Wed 30 Jul 14 @ 7:49 am
