any ideas? it recognizes in the device listing but my mappings do not show up.
thanks
thanks
geposted Thu 12 Jun 14 @ 8:08 pm
For the Korg NanoKontol , which is not natively supported, you will probably need to redo your custom mapping, in case you have mapped the unit as SIMPLE MIDI.
geposted Thu 12 Jun 14 @ 8:11 pm
ok, thanks. i figured as much. i know you helped with the APC 40 issues and figured i could apply the same logic here but it has not worked the same.
geposted Sat 14 Jun 14 @ 9:36 am
