Topic: BPM and Key?
Why are not the BPM and key saved after I analyzed some files?
geposted Fri 13 Jun 14 @ 8:23 am
RobRoyPRO InfinitySenior staffMember since 2012
either you did not add your scanned files to the db or you have set getTagsAuto to "no" ( or possibly both )
geposted Fri 13 Jun 14 @ 8:32 am
Also some tunes don't have a detectable key.
geposted Fri 13 Jun 14 @ 8:35 am
