Topic: Files gone
bogartPRO InfinityMember since 2004
Today and found about 6 files that said "missing files".
Went to relocate and results said could not locate. I tried to locate on drive
outside of VDS and they are completely gone.
I used the same files yesterday and did not delete any of these files.
Don't know if anyone else has had this issue.
geposted Fri 13 Jun 14 @ 9:59 am
Actually maybe,
I've lost a few albums but thought it was my own carelessness and it wasn't an issue because everything is backed up.
Have you searched the recycle bin, windows?
Technical is there a M$ windows log for files being deleted that can be checked.
geposted Fri 13 Jun 14 @ 10:32 am
For the 1.5 hours I used VDJ8 before crashing I had the same issue. Files that were there 2 days ago weren't there last night. Strange... I didn't have any time to investigate as It crashed before I had a chance to look at what was going on
geposted Fri 13 Jun 14 @ 11:10 am
Yep checked the recycle bin, and everywhere else.
Gone!
geposted Fri 13 Jun 14 @ 12:07 pm
If you played it completely, this will register on your History!
geposted Fri 13 Jun 14 @ 12:44 pm
How about previous versions of the folder containing? right click the folder>properties,>previous versions
geposted Fri 13 Jun 14 @ 1:03 pm
