Hi
I can't seem to get a HD widescreen image from my web cam through VDJ.
This is through VDJ (notice the dullness and not in widescreen) :-
![](/image/6065/139153/Capture_VDJ.PNG)
And this is through the official MS software :-
![](/image/60308/139154/Capture_cam.PNG)
Any ideas why the VDJ image is so poor? This happens on both my Logitech and Microsoft webcams and they are both HD widescreen.
geposted Fri 13 Jun 14 @ 12:32 pm
Anyone care to respond to one of your paying customers?
geposted Sat 21 Jun 14 @ 3:14 pm
Have you tried to adjust any of the configurations in the camera plugin?
geposted Sun 22 Jun 14 @ 2:48 pm
Of course, but there's nothing useful in the settings at all.
![](/image/85854/140059/Capture.PNG)
Even if I could put the X and Y coordinates below 0 (which I can't) or increase the size over 100% (which I can't), I would still only be stretching a 4:3 image so it would still not be the correct resolution.
Surely I'm not the only one experiencing this?
geposted Tue 24 Jun 14 @ 1:42 pm
I have the same problem. Notice if you record a videosession, the image gets smaller. I think the resolution aswell. I use recordings to put an enhanced sound to crappy sounding videoclips. After recording, my image becomes 4:3. This should be changed. About camera, I can't chose which cam I want to use. This was possible in VDJ7.
geposted Wed 25 Jun 14 @ 6:52 am
