Topic: Mapping for NumarkNS6
DJ VeonPRO InfinityMember since 2006
I can't seem to find the mapping for the NumarkNS6 for VDJ8, can someone help me with this please. Thanks very much for any help.
geposted Fri 13 Jun 14 @ 1:33 pm
There is no need to use any mapping files. The NS6 is natively supported and it should get detected and work on plug. Just make sure the drivers are properly installed from the numark website (depending on your OS).
Once the unit is plugged and VirtualDj 8 opened, you should be able to see a special button in the AUDIO tab of Config which creates the proper audio setup for you and the unit detected with its name in the CONTROLLERS tab (select the factory default from the Mappings list)
geposted Fri 13 Jun 14 @ 7:54 pm
