this has happened to me 3-4x normally when playing with CU. VDJ 8 closes then immediately reopens. this is on mac btw.
geposted Fri 13 Jun 14 @ 2:29 pm
Same here using numark NS7/V7 not sure if it's a crash or whatever.
geposted Fri 13 Jun 14 @ 6:03 pm
Yes, these are crashes.
Providing you have an internet connection the crash reports will be automatically sent to our servers and the development team can investigate the errors.
If they need to contact you for more information then they will.
Hope that clears it up.
geposted Fri 13 Jun 14 @ 6:08 pm
thanks dan
geposted Fri 13 Jun 14 @ 7:40 pm
