Options within option settings window won't stay open! you can pick the option you
want to configure but then it closes itself within 4 seconds. version 1828.684 windows7
geposted Fri 13 Jun 14 @ 3:05 pm
That happens when I'm in the wrong Config.
Meaning Config 1 is for my contorller and Config 2 is just laptop no controller.
If my controller is hooked up and I'm not in that config (for the controller) on VDJ 8, that happens where the options in configure will close like you said in appx. 4 seconds.
So just make sure that ur actual config is properly set and this will stop. I'm pretty sure this also happens vice versa (meaning set up for laptop only but controller is hooked up, it does ths also) Easy fix, I do it myself ALOT and good luck
geposted Fri 13 Jun 14 @ 3:17 pm
