Topic: VMS 4.1, sync, stop!
Deck 1 is playing, press sync on deck 2, deck one stops dead, embarrassing!
geposted Sat 14 Jun 14 @ 4:01 pm
RobRoyPRO InfinitySenior staffMember since 2012
native v8 mapping ?
geposted Sat 14 Jun 14 @ 6:08 pm
Yes, native mapping. Hard to replicate, but it does it now and then.
geposted Sun 15 Jun 14 @ 3:35 pm
If it is random and not every time it would imply a hardware rather than a software issue.
Tried changing the USB cable? Possible the button in question is damaged in any way?
geposted Sun 15 Jun 14 @ 3:48 pm
You could assign sync to another button (maybe swap functions with another button that you don't use)......
geposted Mon 16 Jun 14 @ 4:54 am
do you have a V7 mapping/ definition still in the mappers/ device folders ?
geposted Mon 16 Jun 14 @ 5:46 am
