Topic: Automix and History
jbezzPRO InfinityMember since 2010
Not sure if this is correct... When I play songs manually, loading them on each decks and letting them play for more then the default 45 seconds they will appear in history folder and get crossed out showing that they played. This is working well. What I am noticing is that songs played with automix do not appear in the history folder or get crossed out! Is this the way its supposed to work or is there an issue?
geposted Sat 14 Jun 14 @ 6:59 pm
geposted Sat 14 Jun 14 @ 7:12 pm
jbezz wrote :
jbezz wrote :
jbezz wrote :
geposted Sat 14 Jun 14 @ 7:14 pm
My Automix is saved in my History.
geposted Sun 15 Jun 14 @ 1:35 am
It works fine. my automix is saved in history too
geposted Sun 15 Jun 14 @ 8:56 pm
