i have a playlist that i created in itunes. i then open virtual dj and the order is different than what i have in itunes. it sorts it alphabetically. i want it to be the same way it's shown in itunes.
geposted Tue 17 Jun 14 @ 9:03 am
Have you tried resetting the sorting order (right click the fields.)
geposted Tue 17 Jun 14 @ 10:35 am
ahhhh! yep. that worked! thanks so much.
geposted Wed 18 Jun 14 @ 11:11 am
Resetting the sort order does work to fix the incorrect order of iTunes playlists in VDJ 8, but it only works after I change the sort order first. I think it's still a bug because it should be the correct order by default. The iTunes playlist ordering wrong in VDJ.
geposted Sat 21 Jun 14 @ 10:13 am
The History Don't stay in the Order the songs was Played ? in VDJ-8 ?
geposted Fri 27 Jun 14 @ 10:31 am
Have you tried ordering by 'Play Time' ?
geposted Fri 27 Jun 14 @ 10:39 am
HI,
It seems to me that I'm having the same problem here.
I wanted to recall my playlist from the party I've played last weekend and i wasn't in the right order anymore...
I have looked for the problem but can't seem to find it.
I did try "play time" but he still won't do it.
geposted Wed 09 Jul 14 @ 2:33 pm
I was having the same issue. I think I have resolved it.
Go to Config, search for sort, change "keepSortOrder" to yes. This seems to have fixed my issue. Hope this helps.
geposted Tue 22 Jul 14 @ 10:47 am
