I asked before (possibly incoherently, I usually do stuff like that) (I ask too many questions) but if you have slip mode on and put it in a loop, allow it to play (let's say 32) and if you change the loop size, VDJ forgets the 32 beats already accrued and starts the slip beat count again from zero.
Is this by design? I can't figure out really why you would want this
geposted Tue 17 Jun 14 @ 10:00 am
Not sure if its by design, it doesnt seem reasonable to me either.
Reported
Reported
geposted Tue 17 Jun 14 @ 6:31 pm
Thanks for the reply djdad, could you update (when known) if the mentioned behavior is intended.
If it is I've already got a loopRoll effect based work around (particularly for loops >4 beats)
geposted Tue 17 Jun 14 @ 7:56 pm
Bump on this one specifically for djdad or other technicians; Is this behavior intended?
geposted Fri 27 Jun 14 @ 9:41 pm
