Topic: Numark OMNI
I am having difficulty setting up my controller with Virtual DJ 8. Under card I have single card; two sound cards and splitter. I am using two decks and headphones. If I use the OMNI controller ASIO sound card my sound quality is poor. If I use the Numark OMNI Audio - WDM 2.19.13 (WASPI) the sound quality is good but I am unable to get my headphones to work. I am only able to make my setup work with a mixture of the ASIO driver and Audio driver. My question is there a better way to setup my Virtual DJ and should I not see the OMNI controller under Card.
geposted Wed 18 Jun 14 @ 8:00 am
Do you get a special button in the CARD tab of AUDIO (Config) which offers the default Audio configuration for the OMNI unit ?
Could you also please do the following and provide us some useful data, since we dont own such a device ...
- From Config-->OPTIONS tab, locate the setting .. CreateMidiLog and set it to Yes.
- Close VirtualDJ, make sure the unit is connected and relaunch.
- Without doing anything, close VirtualDJ again.
- Look at the /VirtualDJ folder and post here the content of the Log Report.txt file you will find there.
As for the possible sound issues you may have with the ASIO drivers, this could be due to bad computer performance. Please spend a few minutes and follow instructions provided here... http://www.virtualdj.com/wiki/Common%20PC%20Performance%20Issues.html or if the ASIO COntrol panel offers any settings, try to increase the latency (buffer) to a safer value - around 10ms
geposted Wed 18 Jun 14 @ 9:18 am
I have adjusted the settings to Master OMNI controller ASIO driver OUT 1 & 2 and Microphone OUT 3 & 4 which works well but the OMNI controller does not appear under the settings audio settings. Please see the log as request below.
WASAPI device without vid/pid: Speakers (Numark OMNI CONTROL Audio - WDM 2.9.13) : {2}.\\?\media#numarkomnicontrolaudioadapter#7&28f11d55&3&id01#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\wave
WASAPI device without vid/pid: Line In (Numark OMNI CONTROL Audio - WDM 2.9.13) : {2}.\\?\media#numarkomnicontrolaudioadapter#7&28f11d55&3&id01#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\wave
Audio device found: name="Numark OMNI CONTROL Audio - WDM 2.9.13"
Audio device found: name="High Definition Audio Device" vid="0x10EC" pid="0x0269"
Audio device found: input name="Numark OMNI CONTROL Audio - WDM 2.9.13"
Audio device found: input name="High Definition Audio Device" vid="0x10EC" pid="0x0269"
Audio device found: asio="ASIO4ALL v2"
Audio device found: asio="OMNI CONTROL ASIO Driver"
Midi out device detected, name:Microsoft GS Wavetable Synth mid:1 pid:27
MIDI Device Identifying: \\?\usb#vid_15e4&pid_0074&mi_00#7&28f11d55&3&id01#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\numark_omnicontrol_midi01 (in:0 out:1)
MIDI Device Identified by PID/VID: \\?\usb#vid_15e4&pid_0074&mi_00#7&28f11d55&3&id01#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\numark_omnicontrol_midi01
MIDI Device Identifying: Microsoft GS Wavetable Synth (in:-1 out:0)
MIDI Device Not Identified: Microsoft GS Wavetable Synth
geposted Mon 30 Jun 14 @ 11:38 am
Try with builds ending at .701 or higher. In order to get the latest controller updates (the last 3 digits), launch VirtualDJ, leave the software running for a few minutes and relaunch (notice the number on the top of the Config window).
The sound card should be now detected properly, and the special button should be there to offer the default audio setup.
geposted Mon 30 Jun 14 @ 2:05 pm
I have run all updates and ensure all my drivers are up to date and still no button for the omni controller.
Please assist
geposted Mon 22 Sep 14 @ 1:25 pm
What build number do you have? Mine is 1970.807
geposted Mon 22 Sep 14 @ 1:52 pm
Can you post here 2 screenshots ?
1. The AUDIO tab of Settings with the Sound card drop down list opened.
2. the CONTROLLERS tab of the Settings.
ty.
geposted Mon 22 Sep 14 @ 3:54 pm
