Topic: Gain, Waveform & Stability Problems
Just a couple of many problems I've noticed.....
Im using a Citronic MPX10/American Audio Versadeck and when I use the platter in vinyl mode the gain of the track jumps up noticeably and then goes back down once i release the platter.
The waveforms I'm seeing on VDJ don't match the sound, by which I mean - you can line up the waveforms perfectly in sync on screen and the audio is miles off from being in time.
While using my other controllers (Torq Xponent, Vestax Typhoon) The program randomly freezes on screen and both controllers become responsive.
Things to note:
I'm using a fairly decent laptop - 8gb Ram, 1TB HD (with music on internal HD not External)
No background programs running besides basic processes
Charger is connected, Battery full and power management set to High Performance
My collection has been fully analyzed
geposted Thu 19 Jun 14 @ 2:42 am
