When going into video settings showing as Video Driver - Intel HD Graphics. I have built in NVIDIA GEFORCE GT 635M but VDJ8 appears to not want to either find this or let me manually select as this is a better graphics card any ideas how I can get VDJ8 to use my NVIDIA ?
geposted Thu 19 Jun 14 @ 7:22 am
When screen is extended for video to my projector, the "windows" surround is been displayed around the video playing out how can I remove this ?
geposted Thu 19 Jun 14 @ 7:24 am
Double-click the video window to make it full-screen.
No need to worry about the adapter shown in options, usually the nvidia is used automatically when a second display is connected.
You can also check the NVIDIA control panel to select which card virtualdj should use.
geposted Thu 19 Jun 14 @ 8:03 am
