Has anyone tried running a Launchpad as well as a "turntable" controller? I'm going to attempt it but I was wondering if anyone else has successfully or not? I also might try and connect a launch control (ordered them both for ableton) so I have more knobs, my mixtrack doesn't have enough controls.
geposted Thu 19 Jun 14 @ 4:18 pm
Not a V8 Bug
If it is midi or HID it should work
geposted Fri 20 Jun 14 @ 6:30 am
The Launchpad series are natively supported in version 8, so you wont have any issues using them at all.
geposted Fri 20 Jun 14 @ 4:15 pm
