Hello dev team, i´m using the new mac beta (23.6.2014) with 2x denon 3900+x1600. The wobbling noise at the beginning of a track is ok now:) The actual problem is an audio dropout/tempo pitch when selecting a new track with the selector knob. Drag and drop has no problem. Loading priority is set to low. That happens only sometimes ,not at every song.
2. If you hold the platter in the song when the motor is running the song will make a pulsating noise after some seconds.
geposted Mon 23 Jun 14 @ 1:36 pm
