Hi,
I'm not sure if anyone else has experienced this issue, but basically, this happens to the VDJ 8 skin upon selecting a playlist Inside a folder on iTunes.
I have only noticed this bug very recently (probably since the latest update).
Does anyone have any suggestions? This happens no matter which skin is selected.
Thanks,
DJ Tiny
EDIT: This is on Build 1845
Thanks,
DJ Tiny
geposted Fri 27 Jun 14 @ 6:45 am
how did you set the fps in vdj ? ( should be 30 by default )
try if there is a difference when fps in vdj set same as display settings ?
windows classic theme ore aero active ?
geposted Fri 27 Jun 14 @ 8:36 am
I am not sure about the FPS, but this was on Windows 8 using the default theme....
EDIT: Closing EVGA Precision X (Graphics Software) seems to have fixed the problem...
geposted Sun 29 Jun 14 @ 3:24 am
