Not sure if this is a bug or not but thought I'd ask/post to see.
In VDJ 7 the order of my virtual folder sub folders would stay the same, how I had sorted them, all the time. In VDJ 8 if I move the sub folders into order but then close the folder it will have reverted to the original pre sorted order. I prefer my sub folders chronological with the newest month at the top (eg 2014-06) but VDJ resorts them by default to 2013-01, 2013-02 etc. up until the most recent month. Is anyone else having the same problem or does anyone know how to fix this please?
geposted Fri 27 Jun 14 @ 4:23 pm
advanced options, keepSortOrder: Yes
geposted Fri 27 Jun 14 @ 4:44 pm
Brilliant thanks!!
geposted Fri 27 Jun 14 @ 6:34 pm
Mine is set to yes but it still does not keep the order. I am using an external drive. Can't we just have a way to right click on a folder and select sort alphanumeric subfolders?
Why is this so difficult to incorporate into the system?
DJ James
geposted Fri 27 Jun 14 @ 8:21 pm
