There seems to be a buzzz in automix whenever the transition is occuring.
Any solutions or comments?
I'm using denon mc6000 on PC
Thanks
Thanks
geposted Fri 27 Jun 14 @ 7:35 pm
Have you checked for bees?
Seriously does this happen in a manual mix? Does it happen with your controller unplugged?, does it happen with your laptop running on battery?
Post a video if you can that might help.
geposted Fri 27 Jun 14 @ 8:14 pm
