Topic: browser option display list as is gone! - Page: 2
Don't use pirated software.
geposted Sat 06 Sep 14 @ 6:10 am
SONG LIST VIEW PROBLEM FOR VirtualDJ8 Browser SOLVED!!!!!!!
Here is what I did to correct that error on my Virtual DJ 8 Pro:-
1) First go to your desktop and delete the VirtualDJ8 shortcut that was created while you were installing the software.
2) Now go to the VirtualDJ8 programs location that should be inside " C: Program Files (x86)/VirtualDJ" .
3) First Run all other Application type files and commands as Administrator {except virtualDj8}
4) Now do the same to "virtualdj8" the Application file that should be red in color; the program should start running.
5) Close the virtualDJ program and go back to the same position to create a new shortcut to your desktop.
It should work correctly now.
geposted Thu 02 Oct 14 @ 2:43 pm
j0babHome userMember since 2014
thanks naffnaftary for your try, but these steps didnt change nothing..
me and other users i know are still stuck in the grid view.
waiting for a proper solution for this ... me to, cant disable the browser grid view :(
geposted Sat 04 Oct 14 @ 7:11 am
is it possible you have a touch screen and VDJ think you are on a tablet?
geposted Sat 04 Oct 14 @ 7:20 am
geposted Sat 04 Oct 14 @ 10:58 am
Hi everybody.
I've got a Pioneer DJ WEGO and that came with a license. After the installation of VDJ7 the program only display the Advanced Setting and I can't use the Wego correctly. Can you help me please?
Thank you.
geposted Thu 25 Dec 14 @ 3:05 pm
geposted Thu 13 Aug 15 @ 12:32 am
Could you be a bit more specific?
geposted Thu 13 Aug 15 @ 1:09 am
timanfHome userMember since 2015
I need to keep my track listing in the order I have it in iTunes for this particular playlist. Is there a way to do this? The program is automatically analysing for BPM etc once each song has been played and rearranging each track accordingly. Would like to avoid this if i can. Cheers!
geposted Wed 09 Sep 15 @ 11:24 pm
If the tracks of an iTunes playlist are re-arranged after analyzed, then most likely the BPM or Key fields in the Browser are selected as sort order.
To get the "original" order of your tracks, right-click on any of the headers (fields names) in the Songs list and select the very first option "Reset Order"
geposted Thu 10 Sep 15 @ 1:00 am
Thanks very much man!
geposted Thu 10 Sep 15 @ 3:50 pm
I had the same problem here running VirtualDJ 8.1 pc build 2587.1086 on a Microsoft Surface which HAS a touchscreen but I'm using a keyboard and mouse and therefore I don't want the GridView, I wanted the List view.
FIXED THIS WAY:
In Options>Advanced options:
Set Browser>GridView to NO
Set Skins>TouchScreenMode to NO.
geposted Sat 26 Dec 15 @ 9:20 pm
This screwed me up at last Friday's gig when moving from one room to the other. I had my Yoga 2 Pro running as a tablet in list mode then closed it whilst moving between bars. When I opened the lid again it was then stuck in grid mode and I couldn't get list mode back so ended up having to reboot then it was still in grid mode. Nothing would change it back.
I had to then go to options, search for touchscreen mode with the onscreen keyboard and set it to no to get the list back which then disables it completely.
This is a serious PITA and an example of bad programming. Why can't the browser have a simple toggle to go between modes somewhere instead of just doing it automatically?
geposted Sat 26 Dec 15 @ 9:55 pm
hi vdj fam had to reinstall vdj8 and "compatible song" list gone from browser did fresh re-install still gone how do i get it back
geposted Wed 06 Jan 16 @ 12:52 am
can anyone help
geposted Wed 06 Jan 16 @ 12:55 am
geposted Wed 06 Jan 16 @ 12:59 am
The "Restore Factory Default" solution, located in the options section, fixed my problem! Thanks!!!
geposted Thu 23 Jun 16 @ 2:00 pm
The search option is missing for me, how do i enable it?
geposted Wed 27 Dec 17 @ 9:57 pm
If you're using the LE version of VDJ 8 then (as you can see from the comparison chart, the browser in VDJ 8 LE is "limited". It has no search.
Ridiculous I know. What's the point of a browser and a database if you can't search it? But that's what Atomix have done.
The solution is to buy a license.
geposted Wed 27 Dec 17 @ 10:56 pm
