Hi, while using virtualDJ8, i have pressed "maximize" and then again on the same button. then, the my windows is shrunk to an unpressable unreadable format. please fix it (and tell me if there is a keyboard shortcut to the "minimize" button because I can't press this button again...
(I have a screenshot, how can i post it here?)
geposted Sun 29 Jun 14 @ 8:36 am
The Maximize e button cycles through 3 options.
Maximize FULL, Maximize (show Windows Toolbar), Maximize WINDOWED (puts VDJ in a window to move around)
With WINDOWS you should be able to resize the window in the lower right corner.
There is no keyboard shortcut but you can add one using the code
minimize
geposted Sun 29 Jun 14 @ 11:13 am
