If I use a playlist I already saved and added or changed it, it automatically saves. Get rid of this ASAP please. Screwed up my playlists and now I have to do them over again.
geposted Sun 29 Jun 14 @ 2:41 pm
Don't forget next time to remove what you don't need, but I think there is an option for auto remove somewhere, read the manual...
geposted Sun 29 Jun 14 @ 3:24 pm
It has nothing to do with autoremove. The playlist simply got overwritten on its own. Not good. I'm on 1845.
Automix also needs "save as"
geposted Sun 29 Jun 14 @ 5:23 pm
prety sure theres a option to turn auto save off .. u may need to enable advanced settings to see it
turn off savePlaylist and they don't get saved unless u ask for it
geposted Sun 29 Jun 14 @ 5:30 pm
I will check out that setting wickedmix.
geposted Sun 29 Jun 14 @ 6:37 pm
