Forum: Wishes and new features
Topic: Useful tooltip info on EQ controls
At present, the EQ tooltips only show a % figure - 50% at when EQ is at 'zero', 0% when fully left & 100% when fully right.
It would make more sense if it showed the amount of dB cut or boost at the selected frequencies.
As is, there's no way of knowing what freqs you have assigned, or how much boost/cut you're applying.
geposted Mon 30 Jun 14 @ 3:38 pm
Well yes and no I agree with pretty much all of what you've said,However a percentage is useful for scripting a setting (for the pov, I mean keyboard users) so both as a tool tip would be ideal
Also just knowing the spec of the eq would be a good start.
