hey guys using Hercules dj console 4-mk been having issues lately in 8 where the controller at times is not detected im also seeing dj console midi show up in controller listing and keyboard that's all . I have always sign out and back in to detect im a pro full user so I don't have to buy a license for the controller.. in addition when this happens I lose control of software and it freezes
geposted Mon 30 Jun 14 @ 8:46 pm
If one time the unit gets detected and working and the next is not, then definitely there is no issue with the software.
How exactly does the software behave when this happens ? Sound stops or keeps going ? Do you get a Windows freeze or the skin freezes (stops refreshing) ?
I would suggest to start with the most common , which is change the USB cable. If that dosnt help, try to disable your Wifi and Bluetooth and take a look at your computer overall performance .. http://www.virtualdj.com/wiki/Common%20PC%20Performance%20Issues.html
geposted Tue 01 Jul 14 @ 4:25 am
hey bob ,skin freezes , and sometimes not I lose full control the controller will no longer respond to vdj 8 sometimes its keps playing or stop in the middle of a song to correct id have to restart the software and sign back in ... I don't ever shutdown the software unless there is an update due to I have an internet radio station on live 365.com the runs 24/7
geposted Tue 01 Jul 14 @ 10:00 pm
..Try this, go into Universal Serial Bus Controllers thru Device manager.
Right click on each "USB Root Hub" and choose "properties", then click on "Power Management" and un-check "Allow the computer to turn off device to save power", then click OK on each... this may be your issue...
geposted Wed 02 Jul 14 @ 12:05 am
