On page 18 of the Virtual DJ 8 users manual, it shows available (I think) effects including, CUT, Flippin Double, and Overlooping - none of which show up as available effects when I run VDJ8? Are these, in fact, available and, if so, why can I not access them
geposted Tue 01 Jul 14 @ 9:52 pm
That part was written before we decide which effects will be included as native. The manual will be updated soon.
The native audio effects are Backspin, Beat Grid, BrakeStart, Distortion, Echo, Flanger, Filter, Loop Roll, Phaser, Reverb, Slicer, WahWah
geposted Wed 02 Jul 14 @ 12:18 am
Rename Cut.dll to cut1.dll, rename overloop to overloop1, flipping double (meh) I never tried, you can recreate that with the beatgrid.
geposted Wed 02 Jul 14 @ 6:23 am
Thanks so much for the quick responses djdad and locodog!
geposted Wed 02 Jul 14 @ 2:51 pm
so beat grid is supposed to work? cause it doesn't on mine ?
geposted Wed 02 Jul 14 @ 10:26 pm
It wont work if you are using a keyboard shortcut or a custom mapper for your controller using the old name which was Beatgrid. The effect is now named Beat Grid, so any assigned actions need to be change to e.g. effect_active 'Beat Grid'
Also make sure that the first parameter of the effect is pointed to a predefined pattern and not to some empty ones.
geposted Wed 02 Jul 14 @ 10:34 pm
