Hello !
First of all , There's a pop up error that says "ASIO SOUND CARD , INCORRECT CONFIGURATION" ( Something like that )
Second of all my controller does not function at all when im in VDJ ..
Could anyone help me??
geposted Fri 04 Jul 14 @ 3:24 am
First, what version of VDJ?
Did you install the ASIO driver for your controller?
What does your soundconfig in VDJ look like?
geposted Fri 04 Jul 14 @ 3:30 am
My version is 7.4 , when i set up the sound config I do it like this : my built in soundcard , no input and no ASIO . I dont know how to install the ASIO sound driver for my controller
geposted Fri 04 Jul 14 @ 3:33 am
Here you could find the driver software.
http://pioneerdj.com/support/product.php?c=3106&lang=en&p=DDJ-WeGO2&t=261
geposted Fri 04 Jul 14 @ 3:35 am
I downloaded it and still my controller doesn't function and the ASIO error shows again
geposted Fri 04 Jul 14 @ 3:39 am
Could you provide some screenshots please?
You did install the driver software now, right?
geposted Fri 04 Jul 14 @ 3:40 am
I installed the driver software ...
Wego turned off:
http://www.siz.co.il/my.php?i=h2mvzmnmkodz.png
Error:
http://www.siz.co.il/my.php?i=nyg4dojeg4mz.png
Wego turned on(After Error):
http://www.siz.co.il/utf8_upload.php?type=1
Wego turned off:
Error:
geposted Fri 04 Jul 14 @ 3:48 am
Please select
Master + Headphone on Input
and your Wego Asio at soundcard section.
Click Apply.
Click Apply.
geposted Fri 04 Jul 14 @ 3:53 am
It doesnt let me select the input , i mean there's no little arrow to select
geposted Fri 04 Jul 14 @ 3:55 am
Ah sorry, I meant OUTPUT. My bad :)
geposted Fri 04 Jul 14 @ 3:57 am
Thats what i get ( my wego is not connected):
http://www.siz.co.il/my.php?i=yy42t2dmmzzz.png
geposted Fri 04 Jul 14 @ 3:59 am
Sure you get this error when your wego is not connected and you try to use its soundcard by selecting it....
geposted Fri 04 Jul 14 @ 4:03 am
and when i try using the wego that configuration menu doesnt even show like i sent i the pictures before ...
geposted Fri 04 Jul 14 @ 4:06 am
when i try using the wego that configuration menu doesn't even show ... like i sent in the pictures before ....
geposted Fri 04 Jul 14 @ 4:09 am
I managed that there will be sound but my controller isn't working (its turned on)
geposted Fri 04 Jul 14 @ 5:00 am
Does it appear (is it listed) in the mapping area?
geposted Fri 04 Jul 14 @ 5:48 am
what do you mean ?
geposted Fri 04 Jul 14 @ 5:50 am
Grooving, he is using a LE version.
He doesn't have the ability or even the tab for mapping.
But that leads to another question.
Is the LE Version you are using the one that came with the controller?
Maybe you want to register your serialnumber in your profile and download and install the LE Version from your download center then.
geposted Fri 04 Jul 14 @ 5:54 am
No mapping tab? So you can't even remap keyboard keys on LE?
DDJWego2User, you could also try downloading VDJ 8 and see what results you get. If that works, you could buy a "controller license".
geposted Fri 04 Jul 14 @ 5:58 am
I've downloaded VDJ 8 and in the settings it says:"DDJ Wego 2 Failed to connect"
geposted Fri 04 Jul 14 @ 6:06 am
