Topic: HELP NOW PLEASE*#!@**!!!
Hi, this is my issue for over 3 years now. I can not continue at all like this.....Please give me a solution, even if it means using other software...I have a big Lenovo laptop with 8 gig of ram and lots of memory, latetst Vdj pro versions and hercules 4mx. WHAT TO DO?!?!?!?!?!? http://www.virtualdj.com/forums/165102/PC_Version_Technical_Support/Distorted_Playback_after_random_amount_of_time.html
I have grounded the 4mx. Problem seems to be related to the (official Lenonvo) power cord I am using, when i dont charge my laptop it seems less or gone. But i cannot play 6 hours set on my battery only of course.....
Thank you!!!!!!!
geposted Sat 05 Jul 14 @ 6:44 am
Hi, did you try on an other computer?
geposted Sat 05 Jul 14 @ 6:49 am
I had a similar problem and it turned out to be my wireless card. Try turning your internet off if you haven't already.
Also, if I opened another program or minimised vdj it would give me bad sound.
geposted Sat 05 Jul 14 @ 6:08 pm
vjmundyPRO InfinityMember since 2014
Search a cable (power cord) without ground. Control your lenguage here please.
geposted Sat 05 Jul 14 @ 6:38 pm
Please keep in mind that this forum is for reporting bugs and issues related to the software.
Thread locked
geposted Sat 05 Jul 14 @ 8:10 pm
